View the thread, titled "retro fit WC and shower water supply" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
M
mr.vangass
Good afternoon, I am looking to fit a shower and WC into a room which currently has no water supply and is a distance from the water mains. i was wondering if it was possible to take a water supply from a radiator loop?
am I crazy?
you can use the radiator loop, if you want to shower in the water that runs through the radiators. which is not recommended at any time due to the chemicals running around the system keeping it clean and clear of sludge. so the answer is deffo NO.
Not to mention the water temperature. 🙂
no dont use your radiator loop - in relation to the room you want to install this wc and shower, where is the nearest cold feed water pipe and soil stack?
the other consideration is even if you do get a hot and cold supply (not from the radiator loop ) Do youhave access to drainage coz if it comes in its gotta go out!!!!
Reply to the thread, titled "retro fit WC and shower water supply" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
