Rinnai Infinity 16i gas water heater - no boiler fittings
View the thread, titled "Rinnai Infinity 16i gas water heater - no boiler fittings" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi, just purchased a Rinnai Infinity 16i gas water heater from Mr. Central Heating. Boiler and flue arrived but fittings are missing. Its got 3 x 1/2 BSP brass male connectors coming out of boiler. What's needed and where do I get it from? Gas installer advised that these should have come with the appliance. Various plumbing merchants all stating the same.
thank you .
Try Mr Central Heating, but it shouildn't be hard for an experienced installer to overcome the issue.
Have you thoroughly checked the box and packaging?
Most manufacturers weigh packed items before dispatch as a final check.
thanks guys, they openly state that fittings are not supplied. Its the first time I've come across this issue, every other appliance has always had fittings with it, which funny enough is what the plumbers merchants are telling me. Problem for me is that as far as I know I need 1/2 union fittings which nobody seems to be selling. Can't just fit a 1/2 female to 15mm compression as far as I'm aware???
Hi Zee, Do not worry about the fittings needed. They are standard 1/2" fittings that any gas engineer will have plenty of in their van, Some multipoints may need 3/4" on the gas depending on gas rate. And The engineer will put in a full flow isolation on the cold inlet as well. They do not come supplied with these fittings.
Hi Zee, Do not worry about the fittings needed. They are standard 1/2" fittings that any engineer will have plenty of in their van, Some multipoints may need 3/4" on the gas depending on gas rate. And The engineer will put in a full flow isolation on the cold inlet as well. They do not come supplied with these fittings.
thanks very much, what do you mean by standard? Just a 'bog standard' 1/2" female to 15mm compression or solder. Rinnai state they want to see a union connection between boiler and pipes for warranty. My gas guy is very relaxed but I want to make sure it all complies.
Sorry Zee that is as far as I will go unless you are Gas Safe Registered. Your engineer will have the right fittings for it on their van.
no worries, I'll check with him again, last time he came to install he didn't have the correct fittings and a lot of swearing was the result, told me to get the correct fittings for the appliance as they should have been supplied.
I can't understand why he did not have the correct fittings in stock on his van....it's standard stock we all have in the van. Did you ask to see his Gas Safe I'D badge? And if a simple thing like basic fittings has stopped the job then I suggest employing another GSR engineer, he obviously is not geared up to do his job properly. Try posting in the find a plumber section there may be one of us guys near you who could help you out. Good luck mate.
thank you very much; I'll probably do that. We have a ton of work; all simple stuff. Mainly just capping so my builders can get in and to be fair my regular guy has not let me down before but always good shopping around I guess. Just get complacent when you use the same bloke for years. Thanks for your help.
double checked with 2 independent gas registered chaps and both confirmed that fittings should have been supplied with appliance and would have to be bought in. Not something that is carried in the back of a van just in case its ever needed. Every plumbers merchant in Leeds is stating exactly the same. Can't believe they are all lying. From personal experience I have never seen an appliance supplied without fittings. Anyway, my advice - don't buy Rinnai unless you want a lot of hassle.
im sorry but there talking out there bum, ive fitted two and they dont come with fittings (its such a common fitting)
and if they dont have them in the back of there van there not gas fitters
cookers dont come with gas flexis
well, all I can say is that my regular gas chap has been registered for 30 years and fitted about a million boilers etc. etc. - why would every other boiler come with fittings but not Rinnai? That is a bit odd innit? If I had known, what a pain it would be I wouldn't have bothered and stuck to regular brands. Anyway, I do appreciate your time to reply/help. thank you
nope quite common, also its not a boiler
its a multi point water heater
other than main (brand) there not that many brands that do water heaters
these cannot be used for heating (just a thought)
Over the years I reckon I have installed at least 500 Rinnai hot water services.
From the 16, 26 & 32.
Never once have I had fittings supplied with the unit.
Do you expect Rinnai to supply the gas valve, water inlet valve and the FI connection for the hot water outlet?
You can buy valve kits for them anyway
Do-Not come with any fittings, and take note of flue length, if above 1.5 Mts you will have to fit a condense collector in the flue, did you get the extra control panel with it ??
ok, just to shed some light on this story now. All installed now (working fine) and according to Rinnai UK the union fittings that are a "MUST" in the installation manual and that in my mind should really be supplied with the appliance are according to their technical department not necessary after all so in other words a very basic 1/2 bsp female iron connector to 15mm compression is sufficient to connect both gas and hot/cold water to the appliance. (this is what some of you were alluding to) Personally I think that this method is a bit 'cobbled' together and defeats the object but hey if the gas man is happy with it and Rinnai too then who am I to complain. Water Heater (not Boiler, I stand corrected) works fine supplying two showers at about 9ltr./min simultaneously. Interesting alternative to a combi boiler or unvented system. (I did not want either) I run the heating on a separate boiler on a vented system. thanks for all your help and advise.
thank you/ did not get an extra control panel for it. Worth buying? Heater is situated in Garage with no access to other than main garage door. I might have answered my own question!?
Reply to the thread, titled "Rinnai Infinity 16i gas water heater - no boiler fittings" which is posted in Boiler Advice Forum on Plumbers Forums.
zee engineer,
ShaunCorbs,
