L
Large human
Hello
In May I had an ideal logic 15 + condensing boiler fitted onto a pre existing y plan system ( the new boiler is a 15 kw the old one was a 10 or 12 kw not sure as it came with the house).
Since installation hot water demand has been fine running from 1 bar cold to 1.7 bar running.
But ....
When central heating is switched on it rises from 1 bar and within a couple of minutes reaches 3 bar .
The first time it did this the PRV kicked in.
I have last week had a new PRV fitted and a new 8 litre expansion vessel (although the engineer fitted a blue potable vessel when the original was a red one).
I have since tried the heating and it remains to rise in pressure but I switch it off as it gets to 2.5 bar before the PRV kicks in..
Any advice given would be greatly appreciated on what the problem could be.
I will be using a gas safe engineer but a sort of second opinion would be greatly received.
Thanks in advance 🙂
But ....
Thanks in advance 🙂
