room stat
View the thread, titled "room stat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
stokecity
Hi guys, when wiring a stat I.e honeywell t6360 where do you take the neutral from for anticipator? It shows from the spur on wiring diagram butt don't think I've ever seen it, most I've seen Havnt got the anticipator wired, can you connect to the main terminal neutral in boiler? Cheers
if the stats cable is going straight the the boiler then take it from there if possible. Speak to boiler manufacturer if needed for advise. you should be fine taking a neutral from any part of the circuit tbh. the no no is using a neutral from another circuit "borrowed neutral"
Or better still use one of the new digital (battery powered) room stats than do not require a Neutral. They are much more accurate (0.5 deg C), have a display showing room temp etc, are only a couple of £££ more to buy etc etc.
It's a no brainer !!!!
Reply to the thread, titled "room stat" which is posted in UK Plumbers Forums on Plumbers Forums.
stokecity,
chris watkins,
