View the thread, titled "Rooom stat help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello I am hoping that some can help me !!
I am trying to replace a room thermostat (as photos below) room stat only works at 30oC (it’s so old they don’t sell them any more) I have bought two room stats today and I have wire them in but it keeps blowing the fuse (3amp)
And suggestions why this keeps happing
I bought
Drayton combistat 24028
Honeywell home MT1 thermostat
If the fuse keeps blowing you must have introduced a dead short by incorrect wiring
is the photo above on the right taken before you took the old one off the wall ?
Short circuit? Any photos of wiring new stats up?
Unfortunately I didn’t get none when wired in 🙁
first two photos are Honeywell
Last four photos are drayton
I hope this helps
I can fit any sort of stat there like a Digital one ?
Depends on the type, as Shaun said. You can get 2 wire ones which just use live and switched and run off batteries. If you want a smart thermostat such as Nest/Hive, then you need permanent live and permanent neutral supplies.
That’s fine
the box which the thermostat talks to goes where your wiring centre is then the thermostat talks to this box with just two wires or just gets power via these two wires
Reply to the thread, titled "Rooom stat help" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
Suffolk
Other Plumber
Thread Information
Title
Rooom stat help
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
stat
Luk3wb,
Aquarius,
