Saniflo & concrete raft to soil pipe (rather than to brick manhole)
View the thread, titled "Saniflo & concrete raft to soil pipe (rather than to brick manhole)" which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
andrew2000
Scenario...
- CI soil pipe on outside wall (1948), neighbour shared, combined foul & storm
- Saniflo some 3.2m from the outside wall, 22mm piping assumed.
- Flooring grade Asphalt, Screed of unknown thickness (1948), Concrete Raft - rebar assumed to be >70mm down.
- Saniflo 22mm outlet pipe fall 1:200 most likely, 1:100 is a bit skimpy re risk of solids buildup
It might be possible to diamond saw the FLOOR for the 3.2m with sufficient coverage for flex conduit and plastic coated 22mm pipe.
Floor level is about 2-2.5 bricks above ground outside.
CI soil pipe has no bottom socket visible.
So does that mean the rest bend is separate (socket below ground) or integral?
Under BR AD H the lowest point for a 22mm boss connector is 450mm above the invert of the rest bend. I hunted last night for some other restriction, but that does appear to be it.
I could lift a 3x2 and trowel away at the clay until I find the pipe, however this is still at the "all possible on the shelf designs" stage. The low level brick manhole cover could have a 22mm low entry, but that part would be outsourced (paved cover, waterproof pipe insulation, UV proof also above terra firma).
Thanks.
Sorry, question was a bit buried 🙂
Q - How TALL is a 1948 Cast Iron Rest Bend?
I have a Straight cast iron soil pipe entering the ground (concrete), which must enter the socket of a cast iron Rest Bend BELOW. The socket is not visible so I presume the ENTIRE Rest Bend is underground.
I need to know the height of a Cast Iron Rest Bend, so I can work out if the DISTANCE from a) Rest Bend Invert Depth to b) 22mm saniflo pipe set into the concrete floor is >450mm.
That is because Building Regs H require any soil pipe Boss Connector to be at least 450mm above Rest Bend invert level.
It saves me having to move a tight fitting 3x2 paving slab and trowel out the clay around the pipe and measure. Obviously I will have to at some point to check - but I am just whiteboard possible solutions.
I like the idea of a very short, horizontal (1:100) Saniflo pipe run - rather than the more usual design using vertical run to ceiling void.
Reply to the thread, titled "Saniflo & concrete raft to soil pipe (rather than to brick manhole)" which is posted in Boiler Advice Forum on Plumbers Forums.
andrew2000,
andrew2000,
