View the thread, titled "saniflow problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
plumber carl
done a few saniflows and always got them running,, as thay were all blocked by debris etc,,, went to one yesterday that was intermittent,, if i flushed the WC once it was dead but if it was flushed say 3 times it started to over flow then say 30 seconds later it ran and pumped away til it was completely empty i tried this a few times and it always did the same thing,,, my thoughts are partly jammed motor? but that would only be if the reset time was under 3 mins,, how long is the reset time?? or the micro switch not kicking in?? its 3 years old,, did saniflow cure the hardened rubber issue for the micro switch be fore this??? any other ideas????
Reply to the thread, titled "saniflow problem" which is posted in UK Plumbers Forums on Plumbers Forums.
