C
cocothecat
i have a saunier duval semia condens f24e when i run dhw or ch it turns off i have to reset it several times until the temp guage reaches about 25 it will then run. If not used for a while i have to repeat the procedure all over again, can anyone help ?
:welcome: to the forum cocothecat 🙂 ...what error code do you see before resetting? Not familiar with your particular boiler but know a thing or two here and there 🙂
)1 points to many causes cocothe cat ... little you can do except maybe check the one and oly plastic pipe (condensate) isn't some how blocked or terminating into a drain that's blocked? Otherwise you need someone to take a look IMHO 🙂
UK Plumbers Forums
Deleted member 120897
