View the thread, titled "Scalding Water From Immersion" which is posted in Bathroom Advice on UK Plumbers Forums.
A
ajni
My hot water from the immersion heater is scalding hot, the water that is heated from the oil fired boiler is fine.
The thermostat for the immersion has been replaced.
I have tried running the hot water until cold them turning the thermostat to its lowest setting and turning it up until it clicks on but the water is still scalding at a low setting.
Could a faulty element cause this ? or is there something simple I am not doing ?
We use the immersion for most hot water needs and my electric bill is a bit nuts every month. Would it pay me to have a plumber split the single channel central heating system to a two channel so I can use the oil fired boiler for hot water without heating the house.
Thanks for any advice,
Andy.
It says Backer BT7 on it.
Also if it makes any difference the thermostat doesn't go into the hot water tank directly it goes into a copper cylinder beside the tank.
1. Your immersion stat is faulty or turned to 80c!
2. Deffo worth getting a quote for upgrading your boiler and system to heat your water.
No way ! someone has left the stat outside its home how daft
no photos allowed from newbies from what i read cause we got hacked badly a while
a go - its a shame but it nearly brought the site down
Moderators will explain I am sure CHKing
If I remember rightly you're in Portadown. Go and see Joe in Bassetts on the Mahon road trading estate, or Simon in Beggs on the Armagh road.
Either of them should sort you out with a new stat.
Reply to the thread, titled "Scalding Water From Immersion" which is posted in Bathroom Advice on Plumbers Forums.
