Scratching my head here with this.
View the thread, titled "Scratching my head here with this." which is posted in UK Plumbers Forums on UK Plumbers Forums.
hammers4spanner
Subscribed
HAve hot water cylinder that have changed the immersion. However have changed it over still not working. Have 240v going through the element and all seems correct but still no hot water
Did you check the immersion spur switch? Could be loose neutral wire there or can be inside the switch.
Remember the switch (2 pole) will have 2 switches actually inside and one of them can be faulty.
Also check at consumer unit or another switch that might be elsewhere.
Use a multi meter
Use a multi meter
Would that still give him 240v to immersion?
Might be a stupid question but, you have left it long enough to heat up? And turned the immersion stat up?
Any reason? I thought this proved if the element was good or not?
I used to subby for Kingspan , in my experience they work or they dont , I have put them in with ridiculously low or high readings and they still work.
If anything if they didnt read right they tended to be noisy , poor insulation I think .
Golden rule with any immersion heater as the ultimate test , wire it up to a plug and put it in a socket, if it works you look towards stat, programmer , spur switch etc etc.
if the immersion is 19 odd ohm then thats around 12 ish KW which means it ok. I would be looking at the integrity if the wiring. The golden rule with electrical work is knowing what your doing
Good idea that
What I would do is 240 L-N and 240 L-E if that's good then turn power of check for continuity across thermostat (or overheat stat as sometimes seperate)
If all of those are ok then faulty immersion.
My guess is the stat as they are shocking.
As above wire it to a plug, plug in to a known good supply with extension lead, see if it works, then wire the stat in see if it still works. Then report back
Centralheatking
As chalked said above, check to see if the immersion heater has an overheat thermostat. This is an additional thermostat beyond the one you can use to set the temperature. The overheat thermostat will trip if the temperature goes too high (85 + degrees) and does NOT reset itself. You have to push in a button, often through a small hole, to reset it.
Reply to the thread, titled "Scratching my head here with this." which is posted in UK Plumbers Forums on Plumbers Forums.
hammers4spanner,
Burger,
