Any eggy smells when you bleed a rad
Correct yes. The system also appears to gain pressure. The filling loop is disconnected l.Gain air? As in you need to keep bleeding rads?
There is just the one inside the boiler, that is currently open.Have you closed all of the auto air vents ?
Not that noted no.Any eggy smells when you bleed a rad
It's just the upstairs rads. Can an expansion vessel fail in a way so that it lets air from it in to the system? I have tested the scrider valve on it and releases air so the diaphram isn't split. I did re charge the vessel as the charge was low. But the problem has carried on.If it’s gaining pressure and the loops disconnected, I’d be looking at e.v. or failed plate hex. With the bleeding of rads, I’d be looking for a leak, or trapped hydrogen. Is it all rads? I find not then try isolating the affected rad/rads and see if the issue remains.
[automerge]1602189153[/automerge]
Have you shut the auto air vent on the boiler. Can these sometimes suck air in to the system?
A leak that was pulling air in?I wouldn’t have thought ev would allow air in. If it’s all upstairs I’d be looking at a leak, but unsure why it would gain pressure. Did you charge vessel correctly?
I did plan on shutting the auto air vent on the boiler after I have filled and fully bleed the system and had it running for abit.Have you closed all of the auto air vents ?
Thanks should shutting the auto air vent on the pump after being fully bleed and run for abit be OK? Or do these really need to be kept open.
Reply to the thread, titled "Sealed system gaining air." which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
