Location - provincial town in West Midlands.
We received this quotation after a personal visit by the proprietor of a local family business that has been trading for some years. It's also some years since we employed a plumber for a major job so we're rather out of touch with costs and would appreciate reassurance that it's not unreasonable for the amount of work likely to be involved. We don't want to waste someone else's time on another quote unless the consensus on here is that the asking price is outrageous. Would appreciate your thoughts.
First quote - for work in 1st-floor bathroom
Dustsheet down all areas and all access routes.
Isolate existing hot and cold water services, and drain down.
Disconnect and remove existing shower mixer taps.
Isolate existing supplies beneath the bath.
Reroute new hot and cold water services from bath tap position to connect on to new booster pump assembly, to be sited to rear of bath behind bath panel. (That end of the bath is against a stud wall separating it from the airing cupboard, which has a hot-water cylinder. Also, it has to be done without moving the bath because of the tiling).
Identify existing shower hot and cold supplies to shower area. (This is a separate shower in its own cubicle on opposite side of bathroom).
Disconnect and remove existing pipework.
Reroute and reconfigure to connect on to booster pump assembly behind bath panel.
Reconfigure supplies from booster pump to connect on to Essex flange, to be fitted to existing cylinder.
Run independent cold supply from booster pump to connect on to cold water storage tank in loft (immediately above bathroom/airing cupboard)
Remove bidet to allow removal of existing tap.
Remove tap from pedestal basin.
Install new bath shower mixer, new bidet tap and new basin tap - supplied by client.
Reinstate bidet.
Fully commission and test hot and cold services and booster pump assembly performance.
Clear away all rubbish and leave site clean and tidy.
All electrical works to connect booster pump will be carried out by *********** and a full test sheet inspection will be provided and registered with the NICEIC.
Materials and labour - £1824.00 including VAT.
Second quote
Isolate existing cold water main service in utility room.
Supply and install Sure Stop water main isolation kit.
Commission and test.
Materials and labour: £141.60 including VAT
Thanks for reading this far 🙂
Reinstate bidet.
Second quote
