Seeping pipe connection to Loft Cold water
View the thread, titled "Seeping pipe connection to Loft Cold water" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Had a problem with hammering noise coming from pipes (triggered by hot water, though it could be eased if you put the cold water on).
Went through everything i could, checking joists etc. Problem appeared to be the ballcock in the loft cold water tank.
Ive replaced it but for the life of me i cant stop seepage out of the nut for the main connection. Though ive only tried
1. Going tighter, getting to the point i'm not sure i can get it any tighter!
2. adding the pfte tape to close any gap
Still getting seeping from the nut, left a tea towel wrapped around it overnight and its soaked this morning.
Im a real newbie and feel the answer is obvious (more tape??) but seems the majority of the job is done, i really dont want to bring someone in but im all out of ideas and know my limits, which are pretty low it has to be said.
For info - I wrapped the tape around the brass thread of the ball cock, no tape used on the cold main thred/nut. See photo
It’s best if you use a 15mm fibre washer to seal the connection. After work on old connectors that require a fibre washer, always put on a new one. You can obtain washers from Amazon, screwfix, tool shed etc.
Reply to the thread, titled "Seeping pipe connection to Loft Cold water" which is posted in DIY Plumbing Advice on Plumbers Forums.
KennyA,
KennyA,
