semia condens f24e boiler problems
View the thread, titled "semia condens f24e boiler problems" which is posted in Boiler Advice Forum on UK Plumbers Forums.
O
older p
boiler cut out after firing up ok. showed fault 1. did as instructed in manual. boiler fires for 8 secs and then stops. have put reset control on reset, red number is now counting down, now stopped at 24, down from 55. Checked condenser. re balanced water pressure. flue seems ok.
however water pressure monitor shows pressure is too high now! how do I reduce that please?
any ideas from anyone or should I get a plumber in!
thanks very much for any help in advance.
thanks Roger - much appreciated!
I guess it needs some TLC. not used very much as it is in a flat - so a good service should sort it out.
hope you are not too flooded out down there in somerset!
so you will be taking your rubber boat to call outs!?
have a good weekend - and again, thanks.
Reply to the thread, titled "semia condens f24e boiler problems" which is posted in Boiler Advice Forum on Plumbers Forums.
older p,
older p,
