View the thread, titled "service plans" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
adrianfs1
hi all, on a one off new build, who would normally design the entire water and central heating system, i suspect that it would be a joint decision between the archetect and the client and that detailed plans would be provided would this be correct,and would the same apply to a completely gutted property, would the local authority not want to see some sort of plans.
realy depends on the size of the building 2up 2 down just get quotes from a few local companies
6 beds 7 bathrooms will need some designs and spec before you get quotes
Hi. Accommodating the building services has often been a compromise from my experience. Forming pipe ducts etc to provide visually pleasing installation is neglected in favor of room size / floor area. Resulting in boxing in and difficult access to pipework/components. Given the opportunity i would certainly investigate the needs with the architect at design level. It may well eliminate disappointing finishes during construction. Good luck
Reply to the thread, titled "service plans" which is posted in UK Plumbers Forums on Plumbers Forums.
