View the thread, titled "Servicing back boilers" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I dont change them as a routine no more that i would change ignition probes on a baxi what seem prone to warping.
I dont think its an experience thing, but if it works for you and you have costed for it then fine. Of course if something gets busted or stripped and they say it was bloody fine before you touched it lol
fires don't tend to get used as much if you think about it... so not so much of an issue, customer wont winge and shout if the fire is out as the heating still works lol....
But they get changed if they look worn at all, after all I am doing the job to earn a living, not save customers money.
I asked this question before as im not a service guy and chris from buckie said "clean em light em and smoke em" and that sort of sticks with me
On a bbu, you must remove the burner to clean. So it's an easy thermocouple swap. Just ask the customer if they want it replacing while your in there. For an extra cost.
Did a Baxi BBU 552 the other day. The fire needed a new thermocouple as pilot wouldn't stay lit, universal ones wouldn't fit so got part number and ordered one £30 plus VAT!!!
I've always used universal thermos, not found a 552 that they wouldn't fit
Lost count on how meny BBUs I've done over the years, and always replaced the T/Couple on boiler unit, for the sake of a fiver, leave it and you can bet you will be back in a couple of weeks. any boiler I do that has a T/C and it gets replaced
I find baxi back boilers ok it's the glowworm ones that catch me out. Removed a back boiler last year on a conversion no idea what make it was but tried to strip as doing a service for future reference but couldn't get it apart
well having been caught out on that theory too many times, my advice to a person doing a bbu is to change the thermocouple everytime, saves call backs and bad tempered customers, you can take the advice if you like or save a couple of quid and be popping back at weekends. if you can ell when a thermocouple is going to survive another 12 months, good on yer, me I can't, so I try and save on some hassle when they fail.
this argument always pops up, all the old boys I know swap, younger folk tend not to, must be something in experience showing out there.
yes,experience tells you if its knackered by looking at the tip,generally a OE Honeywell will give 10 years plus service and before you start arguing with me lame i cut my teeth on bbu,s 22 years ago ,though what i will say is a after market chepie,commonly the £2.50 ones will die quicker
Massood ............... ventilation,spillage,builders opening no holes etc,marble if fitted sealed to opening,all pipes taped,debris plate fitted and sealed,check for secondary flue action,inspect in loft with flue flow and bedrooms,especially important if the chimneys gone and a twin wall set up has been used,check for correct connector to liner if so,spillage test boiler then boiler and fire,this will confirm liners not been crushed,also spillage with any extractors running if fitted
Reply to the thread, titled "Servicing back boilers" which is posted in Boiler Advice Forum on Plumbers Forums.
