if i was in any doubt yes as a rule worcester greenstar every 2-3 years as the deteriorate,vailant/glowworn definatly if a graphite upgrades not fitted ,baxi duotec/pot gold very rarely need doingso if you turned up to do a service and you didnt have a door seal on the van would you go fetch one before commencing? sorry just want make sure i do it right
on a greenstar it might pass fga and negative pressure tests but the burner gasket may be powderflue analyse first to see if you need to strip down oxy and co2 in limits . or check flue neg pressure greater than -3.5 and you dont need to stripdown hexchanger as its clean
no why have you?has anyone on here ever gone to service a boiler and nigh on wrecked it ??
piccies would be goodNo but i do some boiler changes for a H/A comapny and renewed some boilers that have supposed to have been serviced or been in for repair and seem to have been attacked with a machette . makes me wonder what the hell goes on in the service
nothing because they fail between the electrodes before finally torching the boilerif they were powder what would you your negative tests tell you
no every 2-3 years but 3 years is pushing it,yet another reason why i dont like worcester,just changing the fan(which is also weak)means replacing the burner gasketso worcester bosch boilers need stripping down on every service and gaskets replaced ?. everytime you break heat exchanger you need to replace gasket .very expensive services for the customer every year and as worcester bosch claim seals only need doing every 4 year or so.perfect combustion self cleaning and all that
dont glowworm and vaillant say that the burner gasket needs doing every year??
no i think this one has the square hex and a totally different designis the cdi as bad on burner gasket as juniour range
i know a good lad that can give you a hand with this his name is tom tumwent to service a juniour this month its 1 year old and got a rh side exit flue cemented in the wall . dreading doing a full service on this due to the flue covering the access plate where the flue brush has to go
Must of been a pain how did you get on ?
They do come with burner gaskets at least!no every 2-3 years but 3 years is pushing it,yet another reason why i dont like worcester,just changing the fan(which is also weak)means replacing the burner gasket
No only needs changing if disturbed or if the graphite seal hasn't been fitted. Should have a G10 sticker on boiler if graphite seal fitted.
If it doesnt have the G10 sticker then you can also tell my seeing if it has the locking nuts, if no locking nuts chances are it has the old seal
Reply to the thread, titled "servicing question" which is posted in UK Plumbers Forums on Plumbers Forums.
