Servowarm Boiler change
View the thread, titled "Servowarm Boiler change" which is posted in Boiler Advice Forum on UK Plumbers Forums.
dougs.cowan
Hi, I am pricing to replace a Servowarm Elite 30 boiler with a new heat only boiler. As I have never worked on one of these units before and cannot find a manual anywhere online is there anything I should be taking into consideration other than having to replace all the control wiring and the circulation pump as the current one is integral to the boiler? Any help would be greatly appreciated.
a lot of servo warm systems had no header tank just a vase on the wall which had to be manualy filled with a jug not a problem if fitting a system boiler tho
No as you say you will have to fit new programmer and pump,other than that straight boiler swop
System wise however you have to check
You have a header tank and it has mains ball valve refill as some have manual fill and some early typle just had small refill pot in corner of a bedroom,maybe no vent is fitted just 15mm cold feed from tank,will require correcting
Controls need checking as may be hand change over between heating and hot water ,this will require updating to a automatic motorised valve with cylinder thermostat and room thermostat
If you are thinking of pressurising,the rads were good quality but you will probably need new rad valves
Many thanks for the info, a great help. I have had another look after reading your posts and my quote now includes the price of installing a vent pipe as there is not one there currently. The header tank is mains valve fed so no worries there but thanks again for the heads up. Doug
Reply to the thread, titled "Servowarm Boiler change" which is posted in Boiler Advice Forum on Plumbers Forums.
dougs.cowan,
dougs.cowan,
