View the thread, titled "Shower pump advice please" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
N
Nat
Hi all,
Is it bad practice when installing a shower pump to just pump all the hot outlets in the house to save running a new supply to the shower? If so why is that? Is it an issue with noise or wear and tear on the pump?
Also can someone recommend a good quality, quiet, single impellar pump?
Many thanks,
Nat
a) Yes, it is bad practice.
b) Because most pumps rely on the water as lubrication. The normal off-take from a hot water cylinder often allows air in the water - so no lubrication.
c) Agree - Stuart Turner. I've one of their pumps still going after 25 years.
I don't understand your point about lubrication. I would be fitting a proper flange and why would it make any difference if it was a shower or a basin at the draw off point?
Reply to the thread, titled "Shower pump advice please" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
