View the thread, titled "shower pump help needed ......" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
paulyoung666
hi all, looking for some advice on a shower pump , when it works the pump i have works fine , however it is on its last legs , i have a cylinder heated by a conventional boiler , the cylinder is in the loft with the pump at the base of it , cold water tank is above the cylinder and the shower mixer is below the pump in the bathroom , do i just need any common or garden pump for this situation or what , cant afford to spend a fortune but dont want to skimp at the same time , thanks for any help 🙂
Wouldn't fit a garden pump, just stick to the proper shower pumps. Salamander have a good range and are reliable or Stuart turner if you have money. Look on old pump for bar rating and buy same. I take it this is twin impeller?
just had another root around in the loft and found that the hot is fed from the top of the cylinder in 22 mm , but the cold is fed from the tank in 15 mm , this does not sound right to me ......
You have to ask, will 15mm pipe allow enough water for half the supply to a shower. The answer is yes, so if it's not broke - don't fix it.
thanks , thinking on , there is 2 15mm isolating valves 15mm Isolating Valve Pack of 10 | NoLinkingToThis , are they full bore or not ?
No, if they are the same as those screwfix valves. Replace them with full bore lever valves. There are larger slotted screw valves which are full flow.
i changed those 15mm valves for full bore 15mm valves , they were on the outlet of the pump anyway for some unknown reason ! , couldnt get a pump today , however i did a quick flow test of the pipework and have found i am getting ~ 30 l / min off the hot supply and ~ 15 l / min off the cold supply , is this ok ? ......
Not sorted, just worked out there is no Surrey flange on the hot feed , so I need to sort that , or fit an Essex flange , which though ......
Is it installed and working?
What make of pump is it from B&Q Watermill?
If the pump is in the airing cupboard you can fit a Surrey flange if you wish, if the shower starved when someone uses a hot tap?
Yes , installed and running , try and picture this , hot feed comes off the top of the cylinder and runs horizontal for approx 18" , it then tees off horizontally , one side goes up and loops into the cold water tank the other runs down at around a 20 degree angle , about 3' along it tees off vertically into the shower pump , all ran in 22mm , the pump as struggling on he hot side but woks perfectly on the cold side , the pump is at the base of the cylinder in the loft and the shower is beneath the pump in the bathroom , hope all that makes sense .......
right , some more help please !! , just undone the compression nut on the hot water outlet and found this ....
i was expecting a 22mm to 1" screwed adapter in the top of the tank , but no , i have a male thread on the outlet formed onto the top of the tank , help !!!!!!!!!!!!!!!!!!!!!!!!!
right , it is a 1" bsp male thread , so , out of the various options available , is any particular type of surrey / warix / salamander etc flange worth getting over another one ? .......
Reply to the thread, titled "shower pump help needed ......" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
