View the thread, titled "shower pump help needed ......" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
paulyoung666
hi all, looking for some advice on a shower pump , when it works the pump i have works fine , however it is on its last legs , i have a cylinder heated by a conventional boiler , the cylinder is in the loft with the pump at the base of it , cold water tank is above the cylinder and the shower mixer is below the pump in the bathroom , do i just need any common or garden pump for this situation or what , cant afford to spend a fortune but dont want to skimp at the same time , thanks for any help 🙂
Ended up fitting a Warwick flange in the end , working brilliantly now , just a shame the monkey who fitted the shower in the first place didn't fit one , would have saved me a rake of money .......
Its quite rare to see any shower piped up properly to be honest, most are done in the laziest way possible and result in a poor shower. Had one today on a gravity mixer and the hot had to travel such a long and tortourus route through 15mm push fit, it was barely a trickle at the shower head.
Reply to the thread, titled "shower pump help needed ......" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
