M
MattWeth
I've been asked to fit a shower pump (open vented system). I've only done one before and it was a during a new hot and cold installation so easier to arrange the pipework).
The customer will be getting the pump himself (a Salamander, model to be decided) through a supplier which supplies his work (much better discount than I can get). It has to go in the loft next to the header tank. I could just about get it below the tank but it'll be marginal (the tank is on a low plinth in the loft so the top of the pump would just be below the base of the tank).
Would I be better of recommending that he gets a negative head pump to be on the safe side or would a gravity fed pump be ok?
Finally the hot feed from the cylinder...
The existing hot feed has a 90 immediately it exits the cylinder and runs horizontally to the side of the airing cupboard. Would it be ok to tee off this horizontal hot feed, taking it vertically down a foot or so and then bending 180 degrees to go back up into the loft, or should I do it by the book and replace the hot feed with an 'S-flange'?
cheers
Matt
cheers
Matt
