Shower pump under bath? Is this legal?
View the thread, titled "Shower pump under bath? Is this legal?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
mutley racers
Subscribed
I think if i remember correctly, the last time i heard, you were not allowed to install anything electrical under the bath.
Is this right or wrong?
I know lots of people do install them under the bath. And, i cannot seem to find the answer on the net.
Thanks for the help guys
it's not illegal just not recommended and certainly against manufacturers fitting instructions and invalidate guarantee as they need air flow around them for cooling
Most pumps can't be sited there due over heating as no ventilation
Jacuzzi pumps, as mentioned, are made for the job
It's not illegal bit wave good bye to a warranty ad hello to a short life span as it will over heat
from what i can remember from the electrical regs if the bath panel is removable by hand (without tools) then you can not install anything electrical under a bath, if the panel is fixed and can only be removed with tools then you can fit electrical items. best to make sure it has correct ip ratings for water ingress.
if MI state its not allowed then that a different matter.
Nearly. If you can remove the panel without tools then it counts as zone 1. If you need tools then it's not zoned - ie there are no electrical restrictions on what equipment can be under there. And as Gary said I'm willing to bet it's a lot cooler than an airing cupboard!
Reply to the thread, titled "Shower pump under bath? Is this legal?" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
mutley racers,
Plumbstar Tom,
