View the thread, titled "shower pump" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
buttster
help ive been asked to fit a shower pump which will have to live in the loft,the hwc is on the other side of the bungalow and in a small cupboard in a awkward place so fitting a essex flange would be a pain can i fit a surrey flange instead ive never fitted either or a pump before so all help would be very grateful
cheers
buttster
You can tee into the horizontal pipework as it leaves the cylinder. Tee should go downwards and you should then use a bender to get your pipework to do a u-turn if it needs to go in the loft.some shower manufacturers prefer this method as it provides much less flow resistance than a flange and therefore maximizes the shower experience. The feed when done this way is air bubble free because air bubbles don't travel downwards.
If the tank isn't raised then make sure you buy the correct pump,
Stick to the MI on installing the pump you get, have a look at the salamander website, very useful
Manufacturers Instructions, I think a salamander ct50 requires a fall of 600mm from the cold water tank, they're quite easy to install
hi guys thanks for your help i think i will just give it ago like you said kay jay and tap into the the horizontal that leaves the cylindar and put a bend on it.
thanks again
Just make sure your tee comes downwards from the horizontal first before any direction changes to prevent air bubbles being drawn in
if i can out the pump under the hwc which is off the floor about 400-500mm were on the hot can i plumb into and does it make any difference if the hwc is quiet far away from the bathroom thanks
hi can anyone help me ive been told i need a negative shower pump instead of a positive what is the difference and what reason would i need a negative instead of positive
you only need a negative head pump if it is going to be situated above the loft tank. if you put the pump at the base of the cylinder you only need a normal one.
i found a diagram for you showing the pipework arrangement. page 20 of the pdf
[DLMURL]http://www.aqualisa.co.uk/upload/INSTALLATION%20GUIDES/Install_Opto.pdf[/DLMURL]
as you can see this is the 'preferred' method by the manufacturer........flanges eh? who needs em
Reply to the thread, titled "shower pump" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
