View the thread, titled "Shower Wall Arm" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
K
kalunga
Hi - I have a very heavy shower head that by my measurement the thread is 22mm - I am trying to find a Wall Shower arm in Chrome that will fit that 22mm thread - where can I go?
Also - the shower head is very heavy and I have concerns on how this is going to stay in the stud wall - any recommendations? ( bearing in mind the thickness of the arm and also as the arm gets longer the weight of the head gets bigger! )
Any ideas appreciated . Thanks
Hi
I have a 45 degree pitched ceiling through the shower section and access is zero to put in pipe work down from the pitched ceiling. The only area left to use is a 90 degree stud wall that is being put across the pitched roof.
still going to need a arm of some kind - the shower head is 220mm in diameter. The head will be pointing horizontal then?
So does it mean that I need to be looking for 3/4 inch threaded Wall Arms?
Reply to the thread, titled "Shower Wall Arm" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
