Discuss Showers still running on a timed flow valve. in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
W
Wayne B
Hello all.
I have fitted three new Saracen timed flow valves to existing shower rooms.
But these valves are still allowing water to flow from shower head and won't close off.
I have tried various options and sorted other connections in the shower lines 5 on one line 3 on other. Only 1 new valve allows the water to close off if button pulled out, other two this does not help.
Not sure what I am missing but can not find a tech number for the Saracen fitting to ask.
Are they mains pressure showers or gravity eg fed from a tank ?
Reply to Showers still running on a timed flow valve. in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Hi all I had a new bathroom fitted about 4 months ago and all was fine until about a week ago. But now when I turn the lever to run the rain head...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hello all, So been having somewhat of a time with my Aqualisa Quartz 9.5 electric shower. A few.month ago I put up with a few problems it was...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
