Siemens DVA3 3 Port Mid Position
View the thread, titled "Siemens DVA3 3 Port Mid Position" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
I have a faulty Siemens DVA3 3 Port Mid Position Actuator that needs replacing, Can get a Drayton MA1 quite cheap, will this fit in place of the Siemens ! .
Spike
Hi
I am wanting to replace a Siemens DVA3 Actuator ( Mid Position ) have found one on ebay (Used) but says they changed it , but turned out they had to change the whole Valve unit, now on the one they have t says on the label BPZ😀VA3 , mine only says DVA3 , what does the BPZ: mean !.
cheers
Spike
Reply to the thread, titled "Siemens DVA3 3 Port Mid Position" which is posted in UK Plumbers Forums on Plumbers Forums.
Spike47,
king of pipes,
