Single pipe central heating advice
View the thread, titled "Single pipe central heating advice" which is posted in Central Heating Forum on UK Plumbers Forums.
If you're going to put in a new 2 pipe circuit how about hiding the flow and return pipes inside a hollow skirting board instead of lifting the floorboards? You should be able to buy 6mm X 150mm timber strips for the front from a timber merchant.
I have a single pipe loop central heating system and have issues with some radiators not getting hot at all. I have tried changing the valves, radiators, flushing the system etc and the problem must be related to the pipework and / or balancing i think. The flow pipe on the radiators is getting really hot but the water is not flowing through the radiator as the outlet pipe is cold. I have heard that on a single pipe systems the radiators must be close the main feed pipe - in my case they are about 2-3 metres off the main pipe.
I need some advice - is there anything i can try to improve the radiators other than replumbing? (there is a recently fitted wooden floor in the house so want to advoid this!).
Is it common for poeple to replace single loop systems with a feed and return system and what is the typical cost for a 5 bedroom house?
James
Re pipe it to a 2 pipe the only way
I have a single pipe system none of the rads are getting hot I replaced the pump when I turn the pump of the rads become warm tried everything can you help
Reply to the thread, titled "Single pipe central heating advice" which is posted in Central Heating Forum on Plumbers Forums.
james7777777,
Dotty,
