Slow leak from pipe in airing cupboard
View the thread, titled "Slow leak from pipe in airing cupboard" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
L
Liz
Hey all,
I have a bit of a leak in a pipe between the pump and thermostat in my airing cupboard. I'm due to ring a plumber I've been given a number for but does anyone know if this is a quick job to fix and how much it might be? I assume it's a straight forward replacement of pipe?
Liz
Now I don't feel so guilty!:blush5: Looks like it will take more than 2 or 3 hours! You couldn't put a price on that job, as you wouldn't know what you would find.
I am quite suprised that nobody on here has mentioned the fact that when replacing the valves there is very little chance that they will come off from the pump so may be a new pump. or am I missing something.
Jase, you can normally get seized nuts of a pump if you patiently tap the pump nut on each side with two hammers & undo it, or just cut nut with a junior hacksaw till nearly through, & split off with hammer & screwdriver, ( providing the pump valves are actually turning off!!! ). Then renew nuts or entire valves. Only time I would renew the pump is when the pump flange has rotted where the washer seals or if pump is full of corrosion.
Sorry, couldn't resist! If I could get £800 for a job like that, I think I would just hand myself over to " Rogue Traders " before they caught up with me! Might be hard to keep up with my Ferrari though!
Not interested in rogue traders but if I quoted £800 and got the job I'd be laughing all the way to the bank........
Cheers mate, will try it at some point, usually using the hammer works for me with a pump spanner, but I have had some that the pump spanner don't fit on. so will look at the hacksaw idea.
Reply to the thread, titled "Slow leak from pipe in airing cupboard" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Liz,
jase158,
