scottiecb19
Hi All,
I'm having a major panic about a leak on the HW side of my CH system.
We recently had some work carried out by a plumber to replace the pressure reducing valve and pressure relief valve on the cold water feed to the HW system.
Over the weekend I noticed a wet patch appear on my kitchen ceiling underneath the HW cylinder. On closer examination, water was running through the HW run-off, as I could see water flowing through the tundish. Due to corrosion, water was not flowing through the tundish but out of it onto my floor. I understand this needs to be replaced and have come up with a temporary fix using a water bottle to stop further water damage.
However, I am concerned that water is coming through the pressure relief valve. Surely if the pressure reducing valve is working properly, the pressure relief valve should only open if there is an excessive pressure build-up in the HW cylinder. However, even with the cold water supply isolated and HW taps open, the valve continues to leak until, presumably, the water pressure reduces to nothing - then the leak stops.
Big problem is the plumber won't respond to my calls. I don't hold out much hope of assistance, seen as he has failed to turn up to another job he was supposed to do.
I'm just wondering whether it is a fault on the system or just a faulty valve.
Any thoughts/comments would be appreciated!
