small heatrae megaflow pipework query
View the thread, titled "small heatrae megaflow pipework query" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all , i came across a heatre mega flow today and couldn't get my head round something , it was heated via a boiler through the coil but the puzzle is that there was a secondery return from the hot water circut that also acted as the cold feed in seprated by a NRV to stop the hot going back up the cold
Has anyone come across this before .
Cheers
Howy
I read it as hot water secondary is connected to the cold feed to the cylinder correct ?
That's right , the only thing I couldn't get my head round was the fact that the secondary has a pump for obvious reasons
and I thought the in coming pressure and the pump would be out of kilter but I guess it all runs at the same pressure as set by the
incoming cold through the reducer ?
It’s to maximise the capacity of hot water instead of having thermocline layers eg say 30% of hot hot water etc with a destrat pump you would get 75-80% of hot hot water
Reply to the thread, titled "small heatrae megaflow pipework query" which is posted in UK Plumbers Forums on Plumbers Forums.
howy1,
Ricky,
