soil pipe 250 mm from wall
View the thread, titled "soil pipe 250 mm from wall" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
tim d
Hi all, hope someone can help. My soil pipe is 250mm from wall to centre of soil pipe, and going straight down into concrete floor. I cant move the soil pipe without disturbing my drive outside. At the moment I have a false wall built out to accomodate my wc but really,
really want to move in back to the wall properly to give more room at the front. I have looked at twyford alcona bottom outlet which is 205 to centre, would I be able to make up the 45mm with a 40 mm offset connector and a 5mm beading of silican? Or could someone please give me a better suggestion.
Thank you​
Thanks for a reply Mike. Do you mean similar to a s trap and maybe not get a alcona bootom outlet. Is there a s or q trap toilet that will allow soil pipe to double back on itself. Sorry if im getting a little confused.
Yes, the "Q" pan connector is a question mark shaped bent connector which should gain you the distance you need outwards.
Would a q type or swan neck not be sitting under the pan? The back of the pan would be closer than 250mm of which is the distance to the middle of the soil pipe. The soil pipe in level with the floor. Thats why I thought maybe only a pan with bottom outlet would fit.
Reply to the thread, titled "soil pipe 250 mm from wall" which is posted in Boiler Advice Forum on Plumbers Forums.
tim d,
tim d,
