View the thread, titled "Solar Thermal installed - does this look right?" which is posted in Renewables on UK Plumbers Forums.
Hi guy
I had solar thermal installed and wanted an expert opinion, had it installed today and its not working and the installer is to return. I get the impression when it comes to the electrical side the installer hasn’t the foggiest, he replaced the water valve and now my boiler does not heat up , the valve doesn’t turn on, he cut the cable off the old valve and joined the cables and put tape over it. Secondary the solar thermostat/control doesn’t work, so apparently both are faulty, well from what I have seen I don’t think its the equipment. The other cables he has joined as per the pic but no junction box, surely this is not safe. one of pics shows the solar thermostat going’s into the cylinder, should there be a cover? And after all that the installer asked me to double check the joined cable because he is colour blind! Any opinions appreciated. Pics attached. Thanks
Thanks Chuck, and im paying £7500 for this? lol
Not until it's up to standard you're not. You might want to post some pics of the rest of the installation.
That amount should get you quite a nice piece of work IMO. Unless you're in London where it'll just about cover the call out fee and a new tap-washer... 🙂
Sadly unenclosed wago‘s are all too common these days.
it’s certainly not good practice or acceptable, nor is using tape over joints either
write to the contractor outlining your concerns
Yours is missing the tundish totally
Reply to the thread, titled "Solar Thermal installed - does this look right?" which is posted in Renewables on Plumbers Forums.
Thread starter
Joined
Other Tradesman
Thread Information
Title
Prefix
N/A
Forum
Renewables
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
thermal
Husk24,
Husk24,
