T
traineedrip
Noticed on here that someone had done this on another thread.
I have a job in a third floor flat that needs some CH pipe replacing to a rad. Its on a combi so its pressurised.
Its going to be tricky to get a dry pipe as its under boards and Im worried about geting a good solder seal.
I hate the idea of a hidden underfloor compression fitting, especially in a flat. If i cant get a soldered seal with an end feed or yorky is it acceptable to use compression fitting and solder to make it 100% water tight?
So acceptable or is it a no no? It was just a thought having seen it done on here.
