T
traineedrip
If i remove with heat an old end feed joint, leaving me with a silver end to the pipe, can i still get a good reliable seal using a new soldered joint onto the old solder?
yes best to wipe excess solder of the pipe while still hot so you can get the new fitting on what youve done is describes as tinning some thing we used to do a lot when joining lead and copperIf i remove with heat an old end feed joint, leaving me with a silver end to the pipe, can i still get a good reliable seal using a new soldered joint onto the old solder?
Reply to the thread, titled "soldering onto old solder" which is posted in UK Plumbers Forums on Plumbers Forums.
