Solvent Weld minimum distance
View the thread, titled "Solvent Weld minimum distance" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Do you mean something like you have a T and then a short distance away you have an elbow for example. So fitting / joint....bit of pipe fitting / joint?
No there isn't as far as i know. Distances matter for pipe clipping (distance between clip) .
Hello,
To get me out of a situation where I don’t have much p-trap headroom even with an adjustable trap and cutting the waste to lower it would be very difficult.
Consider replacing the standard 90° bend you've drawn with a '40mm 90° conversion bend' and a '40mm coupler'. You might have to shorten the longer leg of the conversion bend but you'll have the 6mm+ you need to work with.
Measure and check everything three times before using the cement, you'll only get one try!
Reply to the thread, titled "Solvent Weld minimum distance" which is posted in UK Plumbers Forums on Plumbers Forums.
Tezzer2022,
Tezzer2022,
