sparky2406
My gas fire which is only about 1 year old has sooty deposits on the glass front, also I have noticed sooty deposits around the fireplace and on the walls.
If I clean the glass, I can see soot building up again within a couple of days.
When the fireplace and fire were installed, a new liner was fitted in the chimney, a smoke bomb test was done, and the work done by a Corgi reg. fitter.
Can anything be done to stop this soot build up?.
Agree with gas man, do not use the fire again until it has been checked out. Sooty deposits on the wall sounds deadly.
"What was that Sooty? Blackcatgas says dont use your gas fire and get in a GSR Engineer"
Just what i was thinking sooty
If you have been using today ,turn off as said and open a window to ventilate the room
