View the thread, titled "Space required for Megaflo + boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
Rusty James
HI,
Could someone tell me what would be the minimum cupboard space required to fit a cylinder unvented/Indirect (210) and a boiler?
- 4 bedrooms house 2 bathrooms
I've checked the manufacture website for sizes but it's doesn't take into account the pipe work needed.
if at all possible get the plumber to install all the system as neatly as possible then build cupboard around it following maufactuers spec for clearences
Depends on the size of your plumber 🙂 Seriously though don't try and cram it all in, a good engineer is what you need as you'll have to allow for servicing and replacement. The manufacturers clearances are only one part of the story.
I guess I will have to see with the plumber if it will be able to fit the all thing in the cupboard I have in mind.
Cheers
its going to depend on the size of the cylinder boiler and ceiling hieght as to wether you can mount the boiler above the cylinder if you can youlll only need the width of the cylinder as all the pipe work can be in front
Reply to the thread, titled "Space required for Megaflo + boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
