M
mikael
Hello,
details;
house built in 1891,
gas central heating system installed in 1986;
gas boiler on the ground floor with an immersion tank upstairs.
Whilst renewing the floor boards in our house I managed to bash a nail straight through a water pipe, I immediately tried to turn the stopcock off but found though it turned, it did not actually switch the off the water coming through the taps or toilet.
In a moment of panic I cut the pipe with the water flowing and whipped on a compression fitting to rejoin the pipe. At the moment the pipe is fine however I am concerned that because it was done with water bellowing out its not a good job and wont last long.
The pipe runs parallel to the central heating system pipe so when the heating is switched on the pipe along side it heats up. The pipe I have damaged does not heat up at all, when I cut the pipe I found water flowed from both directions clear clean water flowed from one end and filthy black smelly water flowed from the other end.
I went out side to try and switch the water off as we have a small 6 inch square metal plate that says “water” on the path however found it was full of sand and when I dug into it couldn't find a tap at the bottom.
So two problems,
  1. pipe needs to be properly repaired,
  2. stopcock needs to be replaced, or at least looked at? Presumably
question, how can I get the water switched off, im assuming the pipe I have damaged is the central heating system pipe, would you agree? And so even if I switch the water off to stop the water coming in, I am going to have drain the whole system out of water?
thanks
mike
yes the pipe you cut is the central heating! the black stuff is deposits from the corrosion in the system. if the compression fitting is not leaking now then it will continue to be ok! (you should add a corrosion inhibitor to protect your system)
you can change the stop tap by using a pipe freezing kit.
KJ
Hi. If you have managed to put the fitting on whether wet or dry the joint should be ok. There are a few different circuit that make up a plumbing and heat system in a house. Its important to know what part of the system the damaged pipe is associated with before specific advise can be given. As for stopcock, if on boundary of property the water company will maintain it for you. Good Luck
Thanks chaps,
Much appreciated
Mike
i would ask your water supplier to install a water meter that way you may save money and be able to isolate the system from the meter and any repairs/ maintenance you want can be carried out
bob
