W
WEDGE
Morning all,
Sometimes even us plumbers need a second opinion...
I called out to a customer the other day with a drilling noise in the loft, I dismantled and re-assembled the fluidmaster pro series side entry valve on the cold water storage tank and reassembled. Everthing was fine and the noise had stopped, I then had another call as the customer complained of a squealing noise in the pipes first thing in the morning when the cold tap in the kitchen was used and the toilet was used as the cold water tank filled up.
Went back out and sods law that evening it was fine and didnt do anything they described after heavy testing. However low and behold it did it again later that night when the tank was filled but not when the kitchen cold tap was used this time, also its done it again this morning.
We all know intermittent faults are trouble I was just wondering if any one may have some advice?
P.S The squealing was described as someone rubbing clean a whiteboard if that makes sense.
Cheers
Cheers
