bungleberg
Could anyone tell me if the distance between the coil in/out apertures are standard across all domestic tanks please.
If you don't need a cyl urgently, u can also order one with other connections or extra ones where u want, for little more, if any extra money. U have to expect some alterations to existing pipes may be needed.A decent plumbing merchant will be able to take your measurements then order one to suit.
... was leaking due to my dearest hanging clothes on the pipe coming from it which made the flange loose...QUOTE]
Just how large are her knickers?
:tongue3:
Never heard of that one before.
:tongue3:
heard of people using automatic air valve for hanging clothes on?
Yes - I assumed that's why they call it an airing cupboard ... :13:
QUOTE]
??? really, they thought of a name like that, before the invented AAV, thats clever.
Essex flanges leak as heat, esp near top of cyl, destroys the " rubber" washers. Touch the pipe & it leaks. You can order a cylinder with 1" tapping near top. You may want to use a Surrey flange or Warix flange on to top of cyl, or pipe by proper method so to hot draw off for air free supply." First hot water draw off below tee" does not mean that that will not be affected by other draw offs, as it will. All that really matters is that shower can't suddenly get hotter, hence thermostatic.The reason I have to change is it because two years ago the essex flange which feeds the hot water to the shower was leaking ....... I want to change the tank and try and take a new connection from the vent pipe but below the vent Tee so its the first hot water draw off.
Reply to the thread, titled "Standards in Hot water cylinder" which is posted in Bathroom Advice on Plumbers Forums.
