Standpipe to Sink Drain
View the thread, titled "Standpipe to Sink Drain" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi, I am looking to install a standpipe to drain the water from the washer. I took a picture of the current set up and my plan. I was wondering if this was correct or if there is a better way.
Sink-> ABS P Trap -> Tee (1.5 in x 2 in x 1.5 in) facing up -> elbow -> pipe to stack
2 in standpipe (min 24 inches in length according to washer manual) connected to tee
Another way I thought was sink -> elbow -> Tee (1.5 in x 1.5 in x 2 in) -> ABS p trap -> pipe to stack
If I swapped the location of the tee pipe and P trap, would that work? So sink -> elbow -> Tee (1.5 in x 1.5 in x 2 in) -> ABS p trap -> elbow -> pipe to stack.
Made a crude diagram below, standpipe would sit just behind the sink.
Reply to the thread, titled "Standpipe to Sink Drain" which is posted in DIY Plumbing Advice on Plumbers Forums.
m_d_r12,
ShaunCorbs,
