Stop tap passing
View the thread, titled "Stop tap passing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
I worked at a house where the internal stop tap was passing. But could isolate in the road. Access to the internal tap for swapping the whole valve isn't great. It it usually ok to split the valve and just change the head? Or even the washer? Thanks
Thanks that little washer on the body doesn't seem like much to hold mains pressure? Is there a possibility of just changing the actual black stop tap washer if there is a problem swapping the body?
Ok I worked on the house and it is passing to swap the full valve would be very awkward. I guess I should really tell the customer? On the external stop tap the plastic on off piece is broke the water board is coming out to change that.
Unscrew the guts, as per your photo, inspect the valve seat.
If the seat is good, just change the black tap washer.
If seat bad, regrind first.
If handle very stiff or graunchy, swap out guts.
If seat too far gone will either have to swap whole tap - or leave it in position fully open and add another tap further up the pipe...
They always come out!
Yours looks nicely clipped but even so, if it’s really tight put a wedge or something between the tap body and the wall - this will stop force on the pipework causing deformation.
Then get out the appropriate sized stilsons and away you go, if you get up as far as a pair of 60’s with no joy - give up!
Reply to the thread, titled "Stop tap passing" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
ShaunCorbs,
