Thanks will give it a try the weekend put it back together as been to work .Should just be able to give it more yes.
Thanks will do.Give it a twist and pull
Yes I did after getting all the mud etc out .Have you turned the mains off at your boundary stopcock??
Otherwise you'll be in for a very cold shower 🚿 😉.
Reply to the thread, titled "Stop tap stuck in blue MDPE pipe compression fitting, nuts undone" which is posted in UK Plumbers Forums on Plumbers Forums.
