View the thread, titled "Stuart turner shower pump" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi guys , I've got a Stuart turner 3.5 bar pump, packed up this morning, makes a buzz like its stuck , stripped it down, was a bit stiff but it ok after moving it. Plugged it in just to test it, it made the same buzz, but when you turn the shaft the pump starts and keeps going, so motor is working. When I reconnected everything, still just buzzing, any ideas what can be causing it?
any help gratefully received.
I don't know much about repairing pumps, but sounds like the capacitor needs renewed. It is what starts the motor, to turn in the correct direction. Induction motors will just sit and hum if capacitor fails unless u turn the motor. Motors with brushes I think don't have them.
I took cover off this morning, capacitor is split at he end with something a bit like solder bursting ll up the ends. Take it that's knackered lol
Hopefully that is your problem. Should be a cheap easy fix! As the pump motor started when you turned it every time, it sounded like only thing wrong could be capacitor - but i only ever repaired leaking pumps. Very common problem on all sorts of motors that use capacitors, like with oil burners.
Reply to the thread, titled "Stuart turner shower pump" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
