Hi
I have come across a problem which should be easy to resolve but is proving difficult. A client has a bath mixer tap with a hose attachment and very little hot water is getting through. They went away for a few days and came back to the problem. Hot water is running fine out of the kitchen and washbasin taps.
I think the washer has probably stuck but I cannot for the life of me get access to the tap. It is a reasonable modern home about 6 years old. Usually you just flip up the top of the tap handle and there is a screw which is unscrewed and you pull off the handle which gives access to the tap.
This one does not have a screw and I have tried pulling up the handle but it is stuck solid. There is no name on the tap but it has an emblem with 3 thick set arrows pointing into each other
Has anyone come across these or has any ideas
thanks
Paul
thanks
Paul
