i posted fire cement 5 days ago, not a word on it. dannypipe mentions it and its a great idea! dans well stole my thunder!! lol
Reactions: 2 people
you used to get a strip of silver tape with a new flue which you were suposed to wrap around the flue to protect it from the concrete.
manufactures seem to have stopped supplying it these days
I rang gas safe on this issue, got some grumpy guy who didnt want to answer any questions or be helpful at all. however i did manage to get out of him before i was told to go away that sand and cement was the only suitable material
thanks for all you replies and I think i'll be ncs all those sealed with expanding foam seals i see on landlord inspections
Most flues are stove enamelled, or painted. I think the tape you mention is for telescopic flues but I could be mistaken. You still get a strip of tape with a lot of them.
Silicon mastic does the job. Valliant say a suitable sealant. The outer flue is low temperature on condensing boilers so i personnally think this is o.k but somebody will prove me wrong......
as with any hole made through an internal or external wall it must be sealed with a material that keeps the specific fire rating of the wall, if the walls fire rating matches the mastic being used then it should be fine.
I've used high temp silicone, but usually sand and cement. Only problem is after a while it can crack on small holes, seen loads that have done it. Might try the fire cement trick.
Sent from my iPad using Tapatalk HD
