Guest viewing limit reached
Supporting pipes under floorboards + insulation
View the thread, titled "Supporting pipes under floorboards + insulation" which is posted in UK Plumbers Forums on UK Plumbers Forums.
What did you do with the risk assessment form???
I understand how the strap band works with the insulation-wrapped pipe. But how do you clip a pipe with insulation around? You'll have to remove a small piece to allow for the pipe clip?
Someone needs to invent a long flexible support you can slide under the floorboard, screw to the joists at each end and then slide the pipes onto it. Job done. Basically doing the job of the plasterboard ceiling supporting the pipes that you run under the first floor.
You mean like this ?
Britclips® Rapid Sliding Wall Bracket
I can only tell you he didn't like it.
You'll manage OK with it, trust me I'm a Plumber.
The foam lagging will fit around the pipe from beneath and kind of envelope the clips, depending of course on the thickness of the foam. If it is too thick then as you already said, you'll need to nip a bit out.
The job is best done from under the floor otherwise you'll be moving furniture as well as lifting floorboards and carpets everywhere. If you go under, you can have it done.
More like this:
https://www.NoLinkingToThis/p/talon...VrZPtCh00uwdAEAQYBCABEgKobfD_BwE&gclsrc=aw.ds
but much bigger and wider to accomodate insulated pipes. You screw slide it 3, 5, 10 metres long below the joists, perpendicular to them, screw it in a few places to hold it then slide all your pipes into it.
More like this:
Use some 100 x 25mm trunking then elec fact should have that
I'm fairly new, thus why I've never encountered a fairly common situation like this before. But I usually encounter situations where I get to run pipes within the first floor. This one is full central heating for a bungalow. About 16 rads. I'm just trying to find a way to run, insulate and clip all these pipes under the floor boards quickly. It's a shame that I may end up using copper out of sight when I could run plastic instead.
Pipes run in the loft means a lot of exposed pipework when dropping down, not as neat as pipes coming up through the floor.
Well if you prefer, why not go under with a battery drill and screw plastic stand off (wrap over) clips to the underside of each joist and use the plastic push fit stuff?
I personally don't like it but I am old fashioned and like you say, no-one will see it.
Apart from the next Plumber of course!
Have you sorted all your pipe sizing for the circuit?
It is a shame, but copper was out long before plastic, and see loads in lofts in the properties I work in, it’s all they used. You need to weigh up the difference, I’m sure there’s not much in it and you’ll be fitting copper - welcome to OldSkool 😀😀😀
Who remembers Hair felt? that used to be popular didn't it? For those who do not, it was highly flammable and very dusty/hairy to work with. You could come out looking like Chewbacca after an hour or two under there wrapping pipes with that.
I remember that stuff, caught some under a crawl space. Went up like a bonfire, first time I'd had to use an extinguisher on the job. Many spiders died that day 😀
Certainly gives the heart a good exercise.
Yes.
This is all bringing back memories. I had a mate who was under a floor and need to take a rest after crawling about so he hunched himself up onto his elbows and put his head up between the joists. As he leaned his head back to rest it on the side of the joist behind and it touched one of the old lead cables which was obviously leaking to earth. It gave him a fair crack and as his head flew forward his forehead hit a brad in the joist in front, lol...... Great days !
I'm not one of those who are all copper and no plastic or vice versa. I just choose whatever is best for the job. Usually plastic wins based on price if it's going to be out of sight. Here plastic seemed ideal at first glance, going under the floor, but with all the pipe clipping, going down the copper route may save me time.
I'll have to run a gas pipe from one end of the house to another, so will be using copper under the floor anyway.
I didn't check joist depth as I didn't consider notching or drilling them.
Reply to the thread, titled "Supporting pipes under floorboards + insulation" which is posted in UK Plumbers Forums on Plumbers Forums.
kasser,
gmartine,
