View the thread, titled "Swapping boiler like for like" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Matt0029
I've been asked to swap a logic that is 4 years old with a split hex. But ideal won't swap hex as the flue hasn't been fit correctly and the turret rubber has been pushed out. Thus been leaking into the boiler and turned everything brittle etc. I haven't seen. Ideal have apparently supplyied a boiler at cost. If swapping people would obviously leave the bracket on if fixed correctly and secure. I'd probably swap the valves. I said the flue would need swapping just as it's 4 years old and the boiler is new. It comes off the turret travels about 400mm then an elbow and exits to outside with the 600mm standard flue. Have I been over top advising the flue would need renewing? Thanks
No, I'd swap the flue too. And in fact I think Gas Safe state that when replacing an appliance it has to have a new flue, certainly a Gas Safe inspector has mentioned that in the past.
Has anyone heard this before the flue turret seal not been fitted correctly/ pushed out. And causing damage to a boiler to be uneconomical repair?
I’ve had them push out normally when the installer lifts the elbow off and the rubber comes with and he doesn’t check before finally fitting the flue and pushes it back on and the rubber doesn’t go in and pushes up
Reply to the thread, titled "Swapping boiler like for like" which is posted in Boiler Advice Forum on Plumbers Forums.
