Guest viewing limit reached
switchmaster 400 replace with horstmann c27
View the thread, titled "switchmaster 400 replace with horstmann c27" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
johnnyphatboy
Hi Everyone
my switchmater 400 dial stopped working so i went on line for a compatible programmer. I found that a horstman c27 would work fine. the switchmaster controlled heating on, hot water on, or both, on a 3 port mid way valve, temperature controlled by roomstat and cylinderstat. when i took the switchmaster of it had, 2 wires to neutral, 1 wire to live, 1 wire to pin 1, and 1 wire to pin 3, ie only 2 control wires. can anyone advise on which pins i should connect 2 wires for full independant control of heating and hot water through the C27 programmer.
thanks
Hope this can help you out 🙂[DLMURL="http://www.thermsaver.co.uk/heating-controls/programmer-replacement.html"]
http://www.thermsaver.co.uk/heating...free-instruction-manuals.com/pdf/p3133382.pdf
[/URL][/DLMURL]
Reply to the thread, titled "switchmaster 400 replace with horstmann c27" which is posted in UK Plumbers Forums on Plumbers Forums.
johnnyphatboy,
Steve @ TheHeatingHub,
